need help findin parts
Old Jan 7, 2011 | 10:29 PM
scottboy69358's Avatar
ive go an 01 3/4 ton dodge that i just lost the nose bearings out of in the front diff where do i start tried jcwhitney but that was hopeless and local parts store cant touch it
Old Jan 7, 2011 | 10:50 PM
SIXSLUG's Avatar
Its a dana 60. Try Randy's ring and pinion.
Old Jan 7, 2011 | 11:05 PM
thanks ive ben tryin tofind parts for about two hours tonight and havnt had very good luck
Old Jan 8, 2011 | 08:51 PM
nitrousn's Avatar
Your looking in the wrong places. Bearings you can get at any parts store. If you need the ring and pinion as said randys, or just about any off road shop. What is a nose bearing???? If thats what your asking for its like asking for a radiator cap for a corvair.
Old Jan 8, 2011 | 09:41 PM
rickf's Avatar
I think he is looking for a pinion bearing. You will need both inner and outer, if one went it took out the other. Check to make sure you did not chip any teeth on the ring or pinion.
Rick
Old Jan 9, 2011 | 01:24 PM
thanks for the help it is pinion bearings pulled the cover plate and checked the teeth all is good there got bearings comin in monday its one part after another any more with this truck
nbaggett89
Dec 26, 2015 09:36 AM
cmtrotter
Oct 28, 2009 08:39 AM
thebabybrahma
Feb 10, 2009 07:43 AM
deereguy07
Feb 2, 2008 12:27 AM
CTD_Neil
Jul 19, 2005 08:13 PM
