need help
need help
does anyone live in or around the dallas tx area that knows anything bout apps im having issues with my 01 i have tried pretty much everything now im to the point to take it to dodge if anybody is close and wouldnt mind helping out i would greatly appreciate it
well it first started out when i was driving in overdrive and would bit a bump my truck would drop down a gear or 2 and wouldnt want to shift back and now when i drive i cant get above 30mph its like the pedal is not giving me the speed i should have at the position i have it in. i can keep the pedal in one spot and it will go then hesitate then go and hesitate
have you cleaned the ground connections?
do you have an analog voltmeter..if you do, find the wire that the APPS output..with key on and engine not running..manually move the throttle.
the voltage should change from near 0 to about 5v.. smoothly..
if its not smooth..search other posts for timbo..and get a replacement apps...if it is smooth...it might be IP.
any idea on the fuel pressure?
any codes in the computer?
what more do you want on xmas
-dkenny
is time for bed..atleast in my timezone
-dkenny
Last edited by dkenny; Dec 25, 2011 at 11:00 PM. Reason: grammer..mine sucks sometimes..
well i dnt think its a fuel issue issue cause sometimes it will drive fine so i ended up taking it to dodge and they came back with a code for my output speed sensor this would explain everything that im experiencing too so they told me they could replace it for 200 bucks so i laughed at them and went and bought the sensor myself spent 16 $$$ the sensor from dodge was 30 and put it in.in the oriellys parking lot now truck runs great . i appreciate your help though i was so lost on this one lol
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
