Is my torque converter going??
Old Jan 14, 2008 | 11:39 AM
89dieselkong's Avatar
I have read a bunch of threads on the TC locking up, but my question is how noticeable should it be? I can definately feel it when it shifts into fourth, enough that it feels like a "thump" and I can feel the tranny, what I can best describe as "bounce" up and down. Only once though as it engages. Is this normal? I only have 61,000 miles on the truck and only run an Edge EZ. Also, how can you tell if the TC is slipping? thanks
Old Jan 14, 2008 | 02:05 PM
hamilton71801's Avatar
The way I knew mine was going out was when I would pull my camper on a long grade, the tranny would shudder or feel like you were driving over a washboard road. Believe me, you will know when it does it.
Old Jan 14, 2008 | 02:07 PM
cincydiesel's Avatar
What he said^ You will also notice the lose of power when you hit the go pedal.
Old Jan 26, 2008 | 08:24 PM
wcbcruzer's Avatar
You know I'm experiencing the same exact thing that you described except mine does it thru all the gears. I've just about had it with this tranny. I wanna bite the bullet and get a fully built tranny but dang they cost too much + labor $$$.
Old Jan 27, 2008 | 03:05 AM
glenn-k's Avatar
The fluid will burn quickly if the TC clutch is going also. I changed only my T/C and valve body. Trans is still great. TC hadn't totaly come apart yet -- frictions but no metal shavings in the trans.
Old Jan 27, 2008 | 06:43 AM
JVDodge's Avatar
When my converter went out I had a few signs. The shutter (pulsating of traction - no trction on the friction disks) was very noticable and while cruzing down the highway when you accelerate your tachometer should not rise 200-300 RPM's. It should stay stable and increase with speed.
If/When you go to replace it, take a look at Suncoast for converters. I have the tripple disk converter and it has not waivered in 110K miles pulling loads up grades regularly.
Food for thought.............
93dieselZak
Jun 16, 2011 06:10 PM
TJE
Jun 1, 2010 05:28 AM
mainer
Jul 17, 2007 07:13 PM
