My 24v cummins ve pump conversion
What makes this conversion any less problematic than a p-pump conversion? I thought the p-pump was considered "better" than the ve, so I'm just curious why you chose the ve over the p.
I thought about doing a p-pump conversion a few years ago and could have bought a complete setup for around $1800.
OK. I've got admit... I don't that much about either the ve or the p other than the ve is a rotary pump and the p is an in-line pump. I gather from what you're saying that the p-pump has a fixed timing regardless of RPM or load, and the ve pump varies the timing much like a distributor on a gas engine.
If you decide to go either route, its probably cheaper to go by a 12v with the desired injection system and rob it to put on the 24v. Or swap in the entire engine. My p-pump swap cost me around $4k (the dollar wasn't as strong then). I bought a running 12v for $1300 later that year. I could have bought the lines for $500, and sold the rest of the 12v for a good bit more than that. Or swap in the $1300 engine and sell the 24v for that or more.
600 Megawatts
May 22, 2008 03:55 PM
12valve
Feb 1, 2006 06:25 PM
heavyboostin
Dec 24, 2005 10:44 AM
Super4x4Duty
Oct 29, 2004 07:04 PM
