multitude of codes
multitude of codes
Ok, about 3 months ago my truck started going to idle while driving, pump the pedal a couple of times and it starts going. tried to pull codes on it and would get nothing. Finally I got a Crank position sensor code. Yesterday, I went to start it and nothing. crank crank crank. then it started. sounding more like CPS to me. I pulled codes again. CPS, TPS, Turbo boost, intake heat etc. Now, I unplugged the edge comp box and cranked it. would that cause all of these codes? I believe the CPS code because I had it once before and it did the same thing. Now the go to idle and pump the pedal a couple of times could be the Throttle position sensor right? maybe a ground wire somewhere with the whole thing?
HELP.
HELP.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
StormTrooper
Mar 28, 2005 09:17 AM
