motor temp question.
I cover my rad almost completely over with card board, have since 2007, there have been many times I've been sleeping in the back seat and my truck was idling at 1200rpm for 5-7hrs at a time, fan has never cut in or when driving around town delivering freight every day all day . rad has never failed due to wind at hi-way speeds.
then again it gets pretty cold here in Alberta
Just my oberservations with my truck
In all honesty, I've never had to use a grill cover. It doesn't ever get that cold anywhere around where I live. The "right way" information I'm sharing comes from the many threads I've read from guys who do use them and have explained the do's and dont's.
I used to put a sheet of cardboard between the intercooler and radiator. I never had any ill effects, and the EGT's were not unusual. I don't haven't done it yet this year, mainly since my wife recylcled my cardboard this summer.
I'm sure that with the radiator blocked off, it also reduces the flow through of air through the intercooler, since there is a large restriction in the air flow path.
It's for a pre 96 7.3 PowerStroke. (Lol) I grabbed the short stem version. It's just a cheapie from Advanced Auto, a Stant. I wanted to see if it would work before buying a nice one from DieselSite. I had to mod it a bit, (Shave the shroud to a smaller diameter) but so far I love it. It keeps the Cummins right around 190 on the gauge but warms up a lot quicker. Gets rid of the cycling issue in the winter with a boatload of ice cold coolant crashing into the water jacket when the stat is fully opened. It still cycles, but it's a bit warmer so the shock isn't as bad. Good heat soak when I duck into a store. It's nice so far.
This is my third winter with it and the cheapie is still working.
cold today, 4 when I left for work.
plugged in all night. Un plugged it started it up and let it idle for about 5 min.
4 miles had fair heat, 6 miles pretty good heat.
sat at work for 13 hours at 14 or so.
6 miles, fair, 8 miles good.
so the new thermostat and flushing of the heater core made a HUGE difference.
Also, I wanted to say that is the easiest thermostat I have ever changed.
thanks for all your advice and input.
Rednecktastic
Dec 18, 2009 08:58 PM
ryan10
Aug 10, 2007 09:38 PM
Common
May 9, 2007 12:11 AM
coupdetat
Feb 17, 2007 12:52 AM
