Maybe down on power??
Old Jan 10, 2008 | 12:58 PM
Grider Pirate's Avatar
It's really hard to tell, becuase I might just be to 'used' to the power now, but it feels like I'm a little down on power in my truck. My lift pump pressure, measured by tapping the fuel filter at the output side, is 15psi at idle, dropping to 9psi at WOT going up a long freeway onramp.
The last 10% of the throttle doesn't seem to add any power, but it DOES generate a bit of screeching noise which MAY be coming from the VP44. Starts easily, no white smoke, no codes. It's bone stock (inlcuding origina lift pump) 3.55 rear, 150,000 miles. No guages except fuel pressure.
Anybody else get that screeching? I don't know how else to descibe it.
Old Jan 10, 2008 | 01:04 PM
1-2-3's Avatar
Just a plain ole guy
Have you had the valves adjusted yet? At 150k, your due.
Old Jan 10, 2008 | 01:21 PM
valve adjustment.
Good point, that's what I plan to do this weekend (weather permitting).
Old Jan 10, 2008 | 06:52 PM
HOHN's Avatar
Screeching? That's hard to place.
If the last little bit of pedal doesn't add any power, then it could be the APPS.
It's hard to prove a negative, right?
Old Mar 6, 2008 | 09:17 PM
Valve Adjustment
I finally got off my backside and checked the valve lash. Since all were within tolerance, that's not the problem. I think the 'problem' may be that I've gotten used to the power it has (relative to trucks I've owned in the past) and it's having a hard time impressing me.
About the valve 'adjustment': First, I was amazed at how clean everything under the valve cover was. The inside of the valve cover itself was CLEAN. Second, if you're going to check your valves, don't assume just because the truck has 150,000 miles on it that you need to replace the gasket. I did, but only because I already bought it. Third, if you've ever adjusted valves before, this will be super easy for you. The only hard part is REACHING for #5 and #6
Total job took me less than an hour. I think I'll just drive it, and forget about my senseless worries.
Old Mar 6, 2008 | 09:34 PM
slowflyer2112's Avatar
Do you have a boost gage?
My truck starts screeching from time to time when the boost comes up and it always means that the exhaust manifold bolts have loosened up. It sorta sounds like finger nails across a chalk board if your old enough to know what that sounds like. Check your exhaust manifold bolts.
Old Mar 7, 2008 | 10:54 AM
Chalk boards? That's new technology! When I was a kid, we had ROCKS.... and we liked it!
Thanks, I'll check out the exhaust manifold.
redcad
Dec 6, 2007 11:21 AM
dank
Oct 15, 2006 10:10 AM
storx
27
Jul 11, 2005 07:23 AM
cumminsdriver635
Dec 17, 2004 02:58 PM
AggiePhil
17
Oct 7, 2004 09:02 PM
