map sensor unplugged. bad results
Old Apr 16, 2007 | 08:01 PM
pigsramdsl's Avatar
Unhappy map sensor unplugged. bad results
unplugged the map sensor thursday night . first impression was great . great take off with lots of black smoke. Then friday evening went to pizza hut came out to go home started truck lots of white smoke and sputtering. did it again sunday at wal mart came out after about an hour lots of white smoke and sputtering. plugged map back in and no problems since. what do you think?
Old Apr 17, 2007 | 07:08 AM
m.rehme's Avatar
Why did you unplug it?
Old Apr 17, 2007 | 07:58 AM
BCSCUMMINS's Avatar
I don’t know about all the white smoke. A lot of people unplug the map with no problems. When I did it my truck didn’t like it, sent the truck into limp mode.
Old Apr 17, 2007 | 08:31 AM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
My question would be also, why did you unplug it...
some of us with the jeep liberty crd in the stable unplug the maf sensor to shut down the acv and the egr to stop the hot exhaust and soot from going back into the intake....
Old Apr 17, 2007 | 09:45 AM
zulusafari's Avatar
I think the idea is to fool the system into giving more fuel early to build boost and smoke more. The Edge EZ takes over the fueling and supposedly fools the computer into believeing there needs to be more fuel. I don't know how it keeps from setting codes and runs the rest of the time, though.
Old Apr 17, 2007 | 11:47 AM
NoSeeUm's Avatar
White smoke is raw fuel going out the pipe.
When you reset your codes which ones did you get?
Jim
Old Apr 17, 2007 | 01:33 PM
sledneck1's Avatar
You can only unplug the map sensor if you have a boost fooling box such as the edge comp, it will dump tons of fuel in at zero boost. Poeple still get mixed results and codes once in awhile WITH boost foolers.
Unpluging it with a stock truck will throw a code and the truck will run like garbage
Old Apr 17, 2007 | 02:06 PM
AggieJustin's Avatar
The Edge EZ is a boost fooling box, so as long as the EZ was still connected to the harness going to the ECM, you won't go into limp mode.
jlebrun
May 2, 2007 07:54 PM
2broke2smoke
Feb 24, 2007 06:28 AM
sledneck1
Feb 18, 2007 05:00 PM
BigBlue
15
May 16, 2006 10:54 PM
j
Nov 23, 2002 05:09 PM
