MAP sensor or Oil Pressure sensor?
Just pulled an oil pressure sensor out of the MAP sensor hole. ( 01 auto 4wd.)
Wonder what that'll make a truck do? How will it act?
Aside from there just not being a MAP sensor in the truck, I'm not sure if there wouldn't be wiring problem or conflict?
Internally they are the same sensor and use the exact same 5 volt supply, the pin outs are the same also, just not sure if the oil pressure sensor would give the same values as the MAP sensor would.
Moobesor
Feb 23, 2008 09:57 AM
Booost Almighty
Jan 1, 2006 01:41 PM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
