lsd price's and option's
Old Oct 27, 2009 | 08:55 PM
2500superram's Avatar
one option the original owner didn't get in my truck was the lsd rear.seem's like a stupid move to me.i should have done my homework on this and not assumed.
i would like to swap another rear into it.i just have a few question's before calling around and searching for one.
what would be the going rate on a used full rear axle(d70)? i don't see a for sale section here to referance,like alot of car forum's i frequent.my truck has a 355 gear in it and i would like to stick with it.
will my rear disc part's swap onto a drum brake axle?i figure it would be harder to find a disc brake lsd rear used.
i really need to get going on this.it's not even just the snow,the truck losses traction in the rain also.it's hard to take a left turn in the wet weather from a complete stop,never mind the crosswalk line's.i'd just like to make sure my 8ft box is out of on comming traffic's way
Old Oct 28, 2009 | 09:54 AM
Midnite's Avatar
Why do you want to swap the entire rear end? Get a Powr-Lok and have a good shop install it--it's better than the stock limited slip and you won't have to worry about swapping the rear disk brake parts.
Mike
Old Oct 28, 2009 | 07:30 PM
hey midnite,thanks for the replie.who make's the power-lok?any link's to a good place to buy one?
Old Oct 29, 2009 | 09:20 AM
Midnite's Avatar
I want to say that it's Dana, but I might be wrong. I got mine for my last truck at a local 4x4 shop and had them install it, but if you want to order it, you might try Quad4x4.
Mike
Old Oct 29, 2009 | 06:52 PM
dropping my truck off at a shop,sounds like it could turn out to be very expensive.might turn in to a $1000 project,after everything is said and done.i'm pretty handy with tool's and usually don't trust people,i don't know work on my stuff.another reason swapping the full rear end would be a better bet for me.
popping the carrier in and out under the truck doesn't sound like fun.the size of it would make it a pain in the butt,i imagine.
i'll start calling junkyard's soon.i just need to find out,about swapping the caliper bracket's for all the drum brake part's.
Old Nov 1, 2009 | 06:00 PM
RockysInMyBlood's Avatar
I've got the lsd rear on my truck. It has marginal usefullness. When I'm in conditions where I'd figure an LSD would help, I just put it into 4 wheel drive.
Old Nov 3, 2009 | 03:04 PM
with an open diff and a truck that make's close to 500 ft lbs of torque,there's no traction in the rain.i've got stuck in the grass with a very small incline and had to put it in 4 high.it's just plain embarasing
tyrsmkr
Dec 1, 2007 11:40 PM
woodperson
Sep 17, 2007 01:09 PM
Diesel-Dan
16
Feb 13, 2007 08:15 AM
amartinson
Dec 10, 2004 04:04 PM
