lp warning light
lp warning light
here's a heads up info post:
i installed the lift pump low pressure light"kit" that comes with the campaign pump, and discovered the sender was bad. so i opened another kit and used it....... works fine now
i think the sender should be tested with an ohm meter before installing.it could possibly save a VP.
the sender/switch is normally closed with engine off, lp pressure over 5 psi opens the switch, and light goes out.
my first sender was always open......
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
NAIL BENDER
14
Jan 14, 2005 07:08 AM
