Lp ?
Old Apr 2, 2005 | 01:05 AM
RAFTEN's Avatar
Lp ?
Changed my lift pump today, not as fast as some reported times but it took awhile to figure out the banjo bolt was not metric. I only found one washer on each banjo, sure seemed like there should be one between the bolt and pump body. I didn't drop them or miss them did I? Runs good with 15 psi at idle and no leaks.
Old Apr 2, 2005 | 05:32 AM
Supermod56's Avatar
The stock banjo's are metric, can't remember what size, so maybe somebody put the hi-flow banjo's in it like mine is, they are 12mm metric threaded but have a standard head. I think the stock ones are 17mm and the hi-flow's are 3/4" or 19mm. And yes, there should be 2 washers per banjo, maybe they are there but stuck somewhere? That happened to mine, I would think it would leak if they were missing. You can get the washers from Geno's or Cummins.
Tom
2001.5 2500 4X4 5-Spd LB QC Black. Catcher ECM, DD Stage-1's, AFE, Bully Dog 4" pipe, ATS Exhaust Manifold, Silencer Ring MIA, JAKE Brake w/shifter switch, Geno's Banjo's, 3 Autometer's on the A-Pillar, Gear Vendor's O/D, Firestone Air Bags, Redline Oil throughout.
Soon-to-have 14cm Turbo Housing and RASP Pump (Thanks Olee!!)
Old Apr 2, 2005 | 11:30 AM
high country's Avatar
If you are missing a washer it will suck air soon and scare the crap out of you! My friend changed his lp and installed a fp gauge at the same time, three days later with great fp it left him stranded. the shop said you need a new ip, well it was throwing a no comunication code from ip to ecm and we just about gave in and then I found a banjo washer in his driveway! replaced it and the truck is as good as new.
So if I were you I would double check to make sure that you did not drop them or perhaps they just stuck to the bolt head, if you are not totally positive I would go buy some new ones and install them or at least carry them as a "just in case"
Old Apr 2, 2005 | 01:10 PM
RAFTEN's Avatar
Just to make sure I am clear about this I'll try a better description. Reason is I have looked everywhere on the truck and in the driveway and found nothing.
I am talking about a washer between the banjo, not the bolt, and the surface of the pump that the banjo snugs up against. There is a washer on the head of the bolt that seals the bolt to banjo surface. There may even be two stuck together but I don't think so.
I have to leave today on a trip so I'm going out and search one more time.
Thanks
Old Apr 2, 2005 | 03:22 PM
RAFTEN's Avatar
Well, heading out on a long trip. No fuel leak after running in driveway. I did see a gasket in the place I am concerned about on the banjo into the fuel filter so I guess I am missing them. Going to the hardware store to get some faucet washers for just in case and you can be sure I'll be stopping at the first Cummins dealer I see.
After searching under the truck and all the running gear I have got to believe the truck never had the gaskets. Sure seems to me the gaskets from both sides would not have vanished, I would expect to find at least one.
Tried calling three dealers in the 3 million people population center I live in and they have no data on a gasket. Really hard to get info on a Saturday. Got to wonder how they change a LP when they don't stock gaskets.
Thanks for the answers.
