low fuel pressure
Old Dec 6, 2009 | 08:31 AM
William Johns's Avatar
low fuel pressure
I have just had installed a Edge Juice/Attitude. It works good on level 1 & 2, but 3,4,5 I get alarm the lift pump pressue is below 4lbs. Has anyone had the same problem? When Edge was installed I had a new OEM lift pump installed also. It idles at 18-21lbs.
Old Dec 6, 2009 | 10:59 AM
johnh's Avatar
if the pressure is 4lbs at wide open throttle, i wouldn't worry about it.... my pressures are about that at WOT and have been for years................ but how many times and how long do you run at WOT? as for me, almost never
Old Dec 6, 2009 | 11:11 AM
When it drops to 4lbs the Edge unit starts beeping and the chip backs down to a lesser fuel supply so as too protect the Injector pump. (this was Edge techs telling me) They also suggested I ad a Fast Fuel System. When does the money/bleeding stop?
Old Dec 6, 2009 | 01:18 PM
johnh's Avatar
when you take the edge off
Old Dec 6, 2009 | 03:07 PM
Copenhagenjunkie's Avatar
It's actually called/spelled FASS. There are also other fuel systems to compare to.
My performance wounds are scabed over but now I am going to be bleeding drivetrain and suspension. It never ends .
Old Dec 6, 2009 | 03:39 PM
SIXSLUG's Avatar
I'm wearing the finish off my wallet pulling it out to keep this thing runnin but I really love the truck. I could find something worse to spend it on.
Kurt
Old Dec 7, 2009 | 08:46 PM
turbo2's Avatar
OK, so here is a little trick to get that winter diesel to flow at the pressure you would like to see. Add a little Howes to your next tank. Get it at the truck stops this time of year. The big rigs use it. Why does this work? I do not know. Does anybody out there have a theory why this works?
Old Dec 7, 2009 | 08:51 PM
Thanks for the Howes suggestion and I will do that, but the temp was in the 60-70 deg range so I think I have other problems
Old Dec 8, 2009 | 10:43 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
OEM lift pumps are JUNK, depending on what model year truck you have.
Old Dec 9, 2009 | 12:18 AM
johnh's Avatar
i've been running a campaign pump on the frame for over 100,000 miles with no problems(knock on wood)
Old Dec 9, 2009 | 09:13 AM
sheriffav8r's Avatar
johnh - what is your campaign pump putting out?
Old Dec 9, 2009 | 09:28 PM
johnh's Avatar
never less than 5psi unless the filter is plugged, which happened this morning (27 below zero)
Old Dec 23, 2009 | 08:45 PM
I just added a B&D after market fuel pump add on and my fuel pressure does not drop below 10lbs. with my Juice set extreme (5) but it is shuting down because of EGT at 1325deg. I was told that I now need a Bigger Turbo. Do you have any sugestions?
Old Dec 23, 2009 | 10:56 PM
Rattletrap1's Avatar
You could put your foot on a diet. ;-)
Do you have exhaust or intake upgrades? Those can drop your EGT a bit.
how much boost are you pulling?
Old Dec 24, 2009 | 07:17 PM
Yes I had big air kit and 4" stainless dual exaust (4" to muffler and 2 4" duals out.
