Locking into 4W High When Stuck
Old Jan 27, 2006 | 03:00 PM
tanderson2002us's Avatar
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
Unhappy Locking into 4W High When Stuck
O.k so I just pulled into a ice packed parking lot this morning, in 2WD and went to park in my spot on a slight hill. I was creeping up into it and sure enough one wheel broke traction. I could not back up due to the paking space arrangement so I went to put it in 4WD. As you know it is hard as heck to lock it in at a stand still so I pushed into 4W High and tried pull forward then back up a little, It grinded and sounded awefull so I pushed it into N then back into 4W High. It finally locked in and I pulled up.
Why is it so hard to lock in when stuck?
Is the grinding as BAD as it sounds?
Is this something that should ALWAYS be avoided?
I have only had to do it about 4 or 5 times since I owned the truck. The worst part is that I drive the biggest baddest rig here and SEVERAL people saw it and were laughing!
Any input appreciated.
Tom
Old Jan 27, 2006 | 04:07 PM
phox_mulder's Avatar
I've never had a problem going into 4HI.
Can't seem to ever be able to get it into 4LOW without grinding, pulling forward a bit, grinding, putting it in neutral, trying again, more grinding, then for no reason it slips right in.
phox
Old Jan 27, 2006 | 04:26 PM
2500Ram's Avatar
No problems ever getting into 4 hi, 4 low the manual suggests rollings very slow about 3 mph and then it slips in, me I'm always stopped and in neutral try 4lo grind, give gas back to idle rpm and it slips in. The thing that's weird is there is no connection between the rpm of the engine and transfer case but it works for me
Old Jan 27, 2006 | 04:40 PM
Hey thanks for the feedback you guys! Its nice to know that I am not the only one who has had an occasional grind or two!
One time I was at a stop sign, flat elevation, stopped on some ice and guess what, the slippage factor! Then the grind factor! It's amazing what I have driven my truck through in 4WD yet a little patch of ice and stop me cold in 2WD unless I am ready to grind a bit......amazing!
Old Jan 27, 2006 | 04:42 PM
iker42's Avatar
I've never had a problem puttin into 4hi or 4lo in Dads truck...only used 4lo once or twice but no grinding
Old Jan 27, 2006 | 04:48 PM
TORQUE's Avatar
I use my 4 wd hi quite often throughout the year, and I can engage mine even while moving at 20 mph without grinding(low you have to stop completely).
Try adjusting your linkage(if it needs it), but you'll probably just have to lube t-case linkages with silicone lube, and work it back and forth, until it is free moving, this will probably cure it. Also try ATF+4 in transfer case.
Old Jan 27, 2006 | 06:02 PM
srt20's Avatar
wait a sec. are you supposed to be slow moving to engage 4hi? i many time will be cruising along at 45-55 and see a bad patch ahead and will let off the pedal move the shifter into 4hi and continue on my way, no grinding or weird stuff ever. have done this on the last 3 trucks i have owned. is this bad?
Old Jan 27, 2006 | 06:10 PM
Timberman's Avatar
I've shifted to 4hi at 45-50 mph a few times. Worked fine for me, don't think it hurt anything. 4 low I just put it in drive enough to move the truck, put in neutral and shift to low range. Works fine. If it grinds just shove the lever harder!
Old Jan 27, 2006 | 06:15 PM
Andy505's Avatar
I never get grinding when shifting into 4HI....I have done it one the highway going 65....when I see snow/ice ahead. 4LOW I dont ever get grinding unless I shift while I am still moving.
Old Jan 27, 2006 | 06:45 PM
TORQUE's Avatar
Sorry for the confusion, should have been 60 +mph into 4wd hi with no grinding, not 20 as stated, typo error and I didn't check it.
Old Jan 27, 2006 | 07:33 PM
Clunk's Avatar
If the trans. is in Drive and you let the transfer case go into neutral, the whole assembly spins and your brakes have no effect on it so trying to get the transfer case back in gear or trans. back in Park gives alot of grind. Shutting the motor off lets you start all over. Basically, don't let the transfer case go into neutral.
Just push in the clutch on manual transmission trucks.
Old Jan 27, 2006 | 08:29 PM
Mopar1973man's Avatar
Clunk got it on the button there...
I've run across the same problem with Mom's automatic... If you hit neutral on the T case you might as well shutdown the engine and start over... You'll never get it back in to gear on a AUTO trans... But on a MANUAL trans... If you hold your cluctch in you can pass into any gear as long as you stopped. If you pause to long on N on a manual yo might get some grind. Pilot bearing will still turn the Trans and T case a bit...
Old Jan 27, 2006 | 09:05 PM
need12v's Avatar
I have no problems with mine. My truck does not have the CAD, so everything is constantly turning in sync. This is the best shifting truck/Jeep/Peice of equipment I have ever had as far as the transfer case goes. And the 5600 is just butter too.
Old Jan 27, 2006 | 09:07 PM
Mopardan's Avatar
Yeah, what he said. I've had 3 shift-on-the-fly 4 wheel drives with an auto. 4hi, smooth 50-55 mph. 4lo, stop> trans in neutral> slam it all the way up. DON'T stop in the neutral position on the T case.
Old Jan 27, 2006 | 09:43 PM
Timberman's Avatar
Yeah, I meant put the tranny in neutral, shift to 4 low, put tranny back in drive. Didn't clarify. Just a little grinding going into low range, enough to let you know something's going on. We tore out some foundation shrubbery new year's eve at about 2 AM. 4 Low is awesome, those junipers didn't stand a chance. Ripped em out by the roots and drug them down the street, had a 99 powerstroke on one side of the porch and my ctd on the other.
