Leaking tailshaft on transfer case
Old Jan 1, 2008 | 04:48 PM
Steve V.'s Avatar
The last time I serviced my truck I noticed trans fluid dripping from my rear driveshaft where it exits the transfer case. The tailshaft on the transfer case is bolted to the case itself with 4 bolts. How hard would it be to replace the tailshaft seal myself?
Old Jan 1, 2008 | 06:44 PM
towpather's Avatar
Should be easy with no need to unbolt the tail piece. The old seal will pry out then tap the new one in
Old Jan 1, 2008 | 07:29 PM
mytrucksaslug's Avatar
I replaced mine with very little difficulty. The hardest part was dropping the driveshaft. You will need a way to push the new seal into the tail off the transfer case. I used an old steel wheel as the center was the same size as the seal. Then i put a 2x4 on top of the tailpiece and beat against that with a hammer to seat the seal. I didn't know i would need to that until i had everything apart. It worked out very good. No problems at all. I dont recall losing much if any fluid. I would be prepared just in case. It's a good time to change to some synthetic oil in the t-case while your down there.
Ramtough
May 30, 2008 07:28 AM
Matt Lambrech
Aug 5, 2007 04:19 PM
Paul-1850
Jan 4, 2007 12:46 PM
