kdp pin
Old Mar 17, 2010 | 01:29 PM
jkrauss's Avatar
kdp pin
I want to buy a Kdp repair kit for my 98.5 24 valve where is the best place to purchase this kit.
Old Mar 17, 2010 | 02:28 PM
larrybartlett's Avatar
geno's garage is where I got mine
Old Mar 17, 2010 | 03:51 PM
Dr. Evil's Avatar
Im pretty sure you can buy it right here from the DTR store. Give Lary a call or PM.
If not, you can get everything you need from Cummins. or like already mentioned www.genosgarage.com - lots of options here.
Old Mar 17, 2010 | 08:50 PM
VPI's Avatar
VPI
I had to do a front crank seal 2-3 weeks back. I just got the KDP kit from Geno's and did it while I was in there.
Old Mar 17, 2010 | 10:14 PM
jkrauss's Avatar
Thanks for the info I orderd one from tst products for $65.00
Thankyou for the info
I did not se it for sale at dtr store
I did se it at genos they get ther kit from tst products after a search online I found tst site and I called them I wanted to make sure I was going to get the right kit , There is two Kdp kits avalable (94 to 98 12 & 24 valve) and (89 to 93 12 valve & 99 to 02 24 valve)
Old Mar 24, 2010 | 12:05 AM
1dumrednek's Avatar
24 valves have the kdp too? is it a big concern?
Old Mar 24, 2010 | 09:20 AM
Andy505's Avatar
yes and very yes
Old Mar 24, 2010 | 09:30 AM
bludodge21111's Avatar
Even for the 2002 24 valves is it really something that needs to be addressed?
Ive only seen something about this twice for the 24valves
Old Mar 24, 2010 | 09:52 AM
Russ Roth's Avatar
Yes it does, IF you have the early cover. Only way to tell is pull it apart, AFAIK.
True, but if yours happens to be one of them with the issue it can be real painful. $$$$
Old Mar 24, 2010 | 07:50 PM
Red3quarter's Avatar
Yes it is something you should address even in a 2002. I tabbed my KDP recently. When i took the cover off the engine I found out my truck did not have the updated timing case! My pin hadn't moved but I didn't want to take any chances so I installed the tab over it. I used the genos kit.
Here's my thread on the subject...
https://www.dieseltruckresource.com/...s-t263311.html
Old Mar 25, 2010 | 07:56 PM
1dumrednek's Avatar
updated timing case?
Old Mar 25, 2010 | 08:29 PM
From what I've read and have been told by others, cummins made a new gear housing that had a stepped hole so the KDP couldn't work it's way out. These were installed on 24v trucks but not every truck got the updated case.
Old Mar 25, 2010 | 09:12 PM
1dumrednek's Avatar
and you have to take the front cover off to check? or can you check through the blow-by hole?
Old Mar 25, 2010 | 09:34 PM
I took my front cover off, i'm sure you could go though the blowby hole with a bore-o-scope. I found loose bolts on the inside of my timing case, so I was glad I took the cover off. It's cheap insurance IMHO.
Old Mar 26, 2010 | 10:40 AM
rebal's Avatar
Like this? ALL CTD need the covers pulled and have the bolts lock tighted in!
I have seen 2 covers blown out by bolts now 1 12v and 1 24v
