Injection Pump/Banjo ?
Old Jul 26, 2004 | 05:28 PM
Ohio Joe's Avatar
First let me start by saying I have noticed diesel leaking for a couple weeks but chalked it up to not replacing the washers with new ones when I added the hi-flo Banjo's. Today the truck started acting like it was missing or not hitting on all cylinders, so I pop the hood and see diesel streaming out of the output side of the injection pump from one of the lines that goes to the injectors.
My question is, should I put the origanal banjo's back on before I have the dealer look at it under warranty? Do you think they will try to say the banjo's caused this, therfore the warranty is void?
Old Jul 27, 2004 | 07:57 AM
gamiller31's Avatar
Make sure the cap nuts on the back side of pump are all tight. The high flow banjos should not be a problem, unless you bent or damaged a line coming out the back of IP while installing.
Old Jul 27, 2004 | 11:25 AM
dodgediesel4x4's Avatar
My local dealer actually liked the fact that I installed high flow banjos. Didn't give me any hassle at all.
Old Jul 27, 2004 | 08:53 PM
Ohio Joe's Avatar
It was a cap nut loose, I fixed it this morning saving a trip to the dealer. I didnt have time to look at it yesterday because I was heading to work when it happened and had to go back and swap cars.
I never thought it would be something so simple. Do the cap nuts come loose often? Must just be all that power shaking them loose
tommurray
Feb 23, 2014 10:38 AM
Dieseldog800
Sep 2, 2006 11:56 AM
stillsmokin
Apr 4, 2006 02:23 AM
Livngood
May 11, 2005 10:05 AM
