How Embarassing
Originally Posted by cummnz4x4pwr
take that lp back to dodge and buy one at napa same exact unit for 85.00 with one year warranty
Originally Posted by red_rattler
But if the lift pump quits working how will it get fuel. Does the injector pump actually pull fuel from the tank. I am confused
I had a few thousand miles with no lift pump and still got another 10 or so thousand out of the Injector after that. The only thing that I noticed aside from no fuel pressure on the guage was a lack of power pulling. Still pulled 10,000 pound plus trailers just slow doing it.
Well i got the truck back today, The new lift pump is idling at 14, 70 mph at 12 and wot about 11. Hope this one last a long time. The good part about the whole deal is the guy only charged me 60 dollars. I don't think i would even fool with it for 60 dollars. All together it cost me about 230 dollars. Not bad. Thanks for all the replies, now i can think about the fass system later on hopefully before this one dies.
Just had the truck towed by a ford wrecker cause the 4th lift pump died.
Ross
Best bet right now with a new LP is to get the Vulcan big line kit, and install a pusher pump in line with the LP. I just did it today, and I cannot pull the fuel pressure below 15psi WOT. I am happy with the setup, and it costs a whole lot less than the FASS.
lift pump
Yes, it WILL pull fuel through a dead lift pump.....and kill itself in the process.
I know it sounds screwy, but that's the way the system works.
I am about to do a Vulcan big line kit/relocate in the next few months and
will just go ahead and put a new pump on mine then. I feel like my lp is living
on borrowed time as it is with 54k miles on the truck.
Makes you want to choke the dodge boys, don't it?
THe truck don't get abused much, I have used additives in the gas several times.
Sorry for the pedantry.
How Embarassing
Yes! both of them pulls fuel and when the lift pump goes out the
injection pump keeps pulling fuel and you are stressing the injection
pump now and it goes out. Sounds like you have another problem
besides lift pump.
besides lift pump.
dodgethis91cmns
Jan 21, 2009 03:22 PM
That,s more embarrasing than the ford pulling me.
