HO Engine ?
Old Mar 28, 2005 | 07:50 AM
CZSteve's Avatar
HO Engine ?
RE: 2001 HO w/ 6 speed
What are the differences between the HO and the regular diesel engine?
Torque, HP, mechanical, strength?
Anything in particular to be aware of when looking to purchase a HO Ram?
Old Mar 28, 2005 | 07:57 AM
hotdram's Avatar
CZSteve,
Try this link here: SO vs. HO (The HO is the ETH engine, the SO is the ETC engine option)
It is from dodgeram.org, a good source of info about these vehicles.
Good luck,
~Rob
Old Mar 28, 2005 | 08:08 AM
hotdram's Avatar
Forgot to mention, no matter what engine, have the fuel pressure looked at. Look at it at idle and during a wide open throttle (preferrably under load but that may not be possible if the gauge is not in the cab). At WOT, the pressure should not drop below about 7 psi (someone else please correct this number if wrong). If it goes to 0, the truck has a bad lift pump. If it is less than 7psi, the lift pump is dying.
~Rob
Old Mar 28, 2005 | 11:13 AM
Supermod56's Avatar
The HO has a higher-pressure injection pump, different injectors, ECM program and a little more compression , that's about it I think. Can't remember the HP #'s One good thing about the HO is it comes with the 6-speed, and the SO comes with the weaker 5-speed. Nothing really to look for, except the dreaded lift pump issue.
Tom
2001.5 2500 4X4 5-Spd LB QC Black. Catcher ECM, DD Stage-1's, AFE, Bully Dog 4" pipe, ATS Exhaust Manifold, Silencer Ring MIA, JAKE Brake w/shifter switch, Geno's Banjo's, 3 Autometer's on the A-Pillar, Gear Vendor's O/D, Firestone Air Bags, Redline Oil throughout.
Soon-to-have 14cm Turbo Housing and RASP Pump (Thanks Olee!!)
alltimelow1
Apr 6, 2005 07:28 PM
Stevenc
Dec 28, 2004 08:29 PM
apache
Feb 22, 2004 05:27 PM
