hesitation only under light/constant acceleration
Old May 16, 2011 | 10:01 PM
mikeg135's Avatar
gentleman,
I have a 2001 Dodge HO with about 115K miles on it. The only mods is an Edge EZ, 4 inch exhaust, and 275 injectors.
The problem I am having is a hesitation under constant or light throttle in all gears and speeds. Giving it some extra pedal, it runs perfectly. It also idles perfectly. I am possibly thinking I might have an injection slightly clogged? I have been googling this problem and have found folks with somewhat similar problems but could not seem to find a solution that has worked yet.
So far this is what I have done and verified without no changes.
1. removed the Edge EZ
2. changed fuel filter
3. fuel pressure gauge states that I am good (12psi)
4. no engine codes
any suggestions to try? The only thing I can think of next is pulling the injectors and soaking the ends in a solvent.
Old May 16, 2011 | 10:19 PM
Tallguy67's Avatar
I am no expert but this sounds like a failing APPS to me. Search on Apps and Timbo Apps - there are good instructions on testing it if you have a volt-meter.
Old May 17, 2011 | 02:44 AM
Heimie's Avatar
From: Stony Plain, Alberta, Canada (just outside Edmonton)
This happened to me with a brand new set of 75hp injectors from DDP. I ended up buying a second set so I could drive the truck (stockers were shot) and sent the first set back for warranty.
Turns out the injectors came back to me with brand new nozzles installed by DDP. (They had less than 1000kms or 600 miles on them) With the new second set of injectors, I never had the problem.
Old May 19, 2011 | 06:32 PM
mikeg135's Avatar
Update:
resetting the APPS seemed to cure the problem. thank goodness that is all it took and was not an injection pump starting to go bad
Old May 21, 2011 | 11:57 AM
SIXSLUG's Avatar
I just had the same problem, actually it was getting worse and more noticeable. I reset the APPS and its gone.
A cheap fix for now anyway!
Old Dec 9, 2012 | 08:43 PM
Don Potter's Avatar
I have a Dodge 2002 1 ton 5.9 24 valve turbo 6 speed manual.
After 50 miles or more, pulling a load or not, but worse when pulling a load. I have no throttle response after deceleration. I have to down shift, get the RPMs up and it goes again. Every time I let off the throttle it starts over, throttle to the floor and no response.
I think I have a good mechanic, but the only fix is to remove the Edge.
Sent back to the manufacturer for testing. After finding nothing wrong and updating the program, it did the same thing again. Doesn't matter what the setting, the only fix is to remove.
Am I missing something? Do I take the chance on a different brand tuner?
Old Dec 9, 2012 | 10:04 PM
SIXSLUG's Avatar
Check for codes.....
smokeybayr
Jun 12, 2007 06:22 PM
Monty
0
Feb 14, 2003 07:14 PM
RJMontana
Feb 14, 2003 06:44 PM
