Help, starter fuse keeps blowing!
Old Mar 7, 2006 | 03:06 PM
WS6HUMMER's Avatar
Its mainly only in the morning, but when I go to start my truck after heating the fuel the 20 amp fuse under the hood pops. This thing has been eating some fuses, everything else seems normal and this only happens once or twice a month on both cold and warm days. Its crazy, the fuse does not blow until its in the momentary start position, sometimes I'll even get 1/2 or 1/4 of a reveloution of the motor before it blows the fuse. I was hoping someone might know about this problem. TIA
Hummer
Old Mar 7, 2006 | 09:19 PM
gunnie's Avatar
could be its time to rebuild the starter
Old Mar 8, 2006 | 12:05 AM
BigBlue's Avatar
Try changing the starter relay. My buddy had this same problem on his gasser and all we did was change the relay and it's worked ever since.
Old Mar 8, 2006 | 07:36 AM
Silverjay's Avatar
Change the contacts in your starter solenoid. They are easy to replace and only cost ~$30.
Old Mar 8, 2006 | 07:38 AM
ds1rider's Avatar
Starter contacts 100%. You could go the cheap temporary way and get a circut breaker in place of the fuse. I've used the circut breaker for a few months, and haven't changed the contacts, but I have them ready.
Old Mar 8, 2006 | 08:11 AM
Geico266's Avatar
Starter contacts. Easy, cheap repair.
http://www.fostertruck.com/dodge/default.htm
Old Mar 8, 2006 | 08:20 AM
WS6HUMMER's Avatar
Thanks! Now the contacts on the Solenoid, are they on the outside or inside of the solenoid? Will I need to pull the starter to do this?
Old Mar 8, 2006 | 08:38 AM
Silverjay's Avatar
The solenoid contacts are within the starter enclosure and you will have to pull the starter.
Old Mar 8, 2006 | 08:58 AM
WS6HUMMER's Avatar
Thanks! Sorry to ask so many questions but where can I pick up some new contacts?
Old Mar 8, 2006 | 07:51 PM
phox_mulder's Avatar
Best ones out there, theoretically.
phox
Old Mar 9, 2006 | 10:27 AM
WS6HUMMER's Avatar
phox
Thanks, sorry I didnt see the link.
Old Mar 9, 2006 | 10:43 AM
singleturnout's Avatar
i had to keep 3 packs of 20amp's in my truck at all times i just replaced the starter and all is back to normal
Old Mar 10, 2006 | 10:52 AM
WS6HUMMER's Avatar
Just replaced the solenoid contacts and man were they worn! On one side the contact was almost paper thin, I dont see how it started @ all. Thanks again everyone for helping me out and pointing me in the right direction!
DodgeDiesel61
Dec 10, 2010 10:12 AM
cginwyo
Jul 18, 2007 09:19 PM
cuda72
Oct 19, 2005 06:02 PM
storx
Aug 24, 2005 07:37 AM
Cumminsdude
Jul 12, 2003 08:39 AM
