Help Fuel Leaks
Old Dec 9, 2006 | 03:57 PM
edy's Avatar
edy
Help Fuel Leaks
I have replaced all of my banjo fittings with a big fuel line kit from diesel dynamics just about a year ago. just within the last month it started leaking around the fuel filter canister i have replaced all the seals and is still leaking what should i do. its not the lid of the canister either. thanks for any help
Old Dec 9, 2006 | 09:36 PM
DL1221's Avatar
When ever I can't find a leak the first thing I do is clean the area really well with either engine degreaser or brake cleaner. Once your area is clean and dry, start the engine and get down there with a flashlight and try to follow the leak to where it starts. You either have a loose fitting somewhere, your fuel hose has a hole in it, or your filter housing is not sealing well. Hope this helps.
abchoppers
Jan 26, 2011 05:38 AM
michcumm
16
Apr 10, 2008 08:49 PM
97catintenn
Jan 14, 2004 10:05 PM
KATOOM
May 2, 2003 05:19 AM
