head gasket
Old Dec 13, 2010 | 11:01 PM
johnh's Avatar
head gasket
i finally bit the bullet and decided to replace the head gasket after smelling antifreeze for more than 5 years......the deciding factor was the little drip off the rear of the engine......at first i thought the freeze plugs were the problem, but every thing in that area was dry........i could see evidence of antifreeze above the starter on the block, so i'm having industrial injection do the job......i am going to take some pics of the cylinders to see what kind of wear is there
Old Dec 14, 2010 | 07:24 AM
jrs_dodge_diesel's Avatar
You wouldn't happen to have a 53 block would you?
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
Old Dec 14, 2010 | 09:22 AM
johnh's Avatar
nope! but i have close to 250,000 miles on it
Old Dec 24, 2010 | 11:19 PM
johnh's Avatar
update on the head gasket, as suspected the leaks were on the passenger side front and drivers side rear. just coolant leaking to the outside.
no indication of internal leaks..........
the head was cleaner than i thought it would be, almost no carbon.......the block is as clean, these pics were taken before any cleaning was done
Old Dec 25, 2010 | 07:34 AM
rickf's Avatar
250,000 miles and still have crosshatching in the cylinders! Amazing!
Rick
Old Dec 25, 2010 | 08:00 AM
Copenhagenjunkie's Avatar
Rick
I had 340k when I did a head swap and still had cross hatching.
Johnh- are you going to have the head magna fluxed?
Old Dec 25, 2010 | 09:22 AM
johnh's Avatar
yes, it's done........
Old Dec 25, 2010 | 09:24 AM
johnh's Avatar
Rick
i think all cummins have that,unless air cleaner problems take them out
Old Dec 25, 2010 | 03:23 PM
fschiola's Avatar
Exactly what I was thinking.
Old Dec 26, 2010 | 08:10 AM
DodgeRam24V's Avatar
how many hours did that take? i have to do one on the 99, i finally found the culprit of the green dots in the driveway. mine is at the rear only, down the bellhousing, onto the FASS wiring harness, to the ground.
Old Dec 26, 2010 | 11:57 PM
johnh's Avatar
around ten hrs complete , r & r head . cleaning and inspection
Old Dec 27, 2010 | 01:05 AM
Tate's Avatar
Looks like you have pretty high timing, or wide spray pattern on your injectors, as your fuel is spraying out of the bowl a bit.
Old Dec 27, 2010 | 09:28 AM
johnh's Avatar
it's what the edge comp does, although it could be the results of an occasional use of propane
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
