fuel pressure figures
Old Apr 28, 2005 | 01:31 PM
ralphie's Avatar
Where do the minimum desired fuel pressure figures I see come from? It seems like most accept 14-15 at idle, 11-12 crusie, and 9-10 for WOT, or something similar. I hear that dodge dealers do a volume test. Who came up with this pressure figures?
Old Apr 28, 2005 | 02:36 PM
HOHN's Avatar
As long as it's between 5 and 15, you're fine.
Over 15 is not ideal, but lots have run up to 20 safely. The VP doesn't like high pressures- Bosch has it set to bypass fuel at 14 psi at the inlet.
It takes at least 5psi to fill the plungers inside.
So it's like the three bears-- you don't want too much or too little. Need "just right."
jlh
Old Apr 28, 2005 | 02:41 PM
RustyJC's Avatar
HERE is the volume test. Prior to this, Dodge used a pressure test, but as of this 5 minutes, I can't find the pressure acceptance/rejection criteria. Maybe someone else still has it.....
Rusty
Venom617
Oct 6, 2004 08:04 PM
Dieseljunkie
Jun 6, 2004 11:53 AM
sandpuller2004
Apr 29, 2004 04:37 PM
HeavyFuel
Mar 24, 2004 03:20 AM
hotdram
Sep 18, 2003 02:21 PM
