Fuel issue
Old Feb 6, 2008 | 08:57 PM
joshuaray's Avatar
Fuel issue
I have a 2001 dodge, that i ran out of fuel. (I know dumb) I have changed the fuel filter twice, but i cant get it to run smooth. I will start and idle for a few minutes, even allow to run up to 3000, then begins to cough and sputter and billow white smoke... ultimately dies. No power, and i cant get it straight? any clues, I am at a loss ( yes i did fill it back up with diesel not gasoline)
Old Feb 6, 2008 | 09:45 PM
dssimecek's Avatar
Do you have any codes? Turn the key on-off-on-off-on, but don't start the truck. Odometer window will show p pcm and if there is a code it will display it then done. Wait a few seconds and it will check the ecm and give a code or show done.
Do you have a fuel pressure gauge?
There will be others that know a lot more about 2nd gen then I do. But is a place to start.
Old Feb 6, 2008 | 09:56 PM
joshuaray's Avatar
codes
I will check for them in the morning, sorry no fuel pressure gauge, I have buddies who tell me i need them! So i better look at getting them
Old Feb 7, 2008 | 01:43 AM
dieselcarpenter's Avatar
Exclamation Wrong forum
Well this one is going to get moved! (to bad all the admins are asleep) For future reference questions of this nature go in the respective forum for your year truck! You get alot more help when all the guys with your year rig can see your posts! good luck!
dan123dbl
Feb 13, 2015 05:47 PM
440727
Jun 20, 2011 10:55 PM
nuhuskersfan1
Jun 25, 2004 08:42 PM
DDysput
May 5, 2004 07:44 AM
