Front Driveshaft binding
Old Dec 3, 2009 | 09:15 PM
hntnbova's Avatar
Short history, I had a skyjacker 4.5 lift put on the last week of July. I also had the front diveshaft rebuilt in July due to a bad u-joint in the cardan. Last week the cardan joint pin snapped due to binding. Took it to driveline shop and truck only has 1" of travel before binding. Have any of you guys had this problem with your lift or leveling kits. Any sugestions for a fix
Thanks
Old Dec 5, 2009 | 07:16 PM
DIESELWRKS's Avatar
well I can give you my 3 cents. I have a 6" lift and replaced all of my u-joints on the front shaft. I havent had any bind issues on mine. I do have a little play on the slip shaft part due to it extending out. if someone else rebuilt yours you may want to make sure the parts were correct. with your lift you shouldnt have issues on binding. www.quad4x4.com has great replacement stronger parts. also could look at tom woods front shafts as well. if they rebuilt your double cardigan joint. did they put in the right cardigan? when I did mine If I remember I used napa joints super joints. and used the ones with the grease plug on the end cap. I just think either bad install, wrong parts. ? hope this helps alittle
Old Dec 5, 2009 | 09:36 PM
dozer12216's Avatar
Perhaps caster is too great.
Old Dec 6, 2009 | 03:27 AM
DIESELWRKS's Avatar
for front caster how can that be corrected. I shimmed my rear carrier to change angle on the caster. are there different front yokes that could be used for this? just wondering.
Old Dec 9, 2009 | 09:53 PM
hntnbova's Avatar
actually the rebuild was just new u-joints and rubber bushing on center pin. So cardan is original flex. Can't say as if they adjusted caster when they installed lift. Tried 3 different cardan joints at driveshaft shop and all would only give me 1" down travel before binding.
esde
Apr 14, 2010 06:41 AM
herb101
21
Dec 15, 2009 10:27 PM
95black2615
Jul 22, 2006 02:19 PM
dave78
22
Jan 5, 2006 06:09 PM
JC19
26
Feb 6, 2005 11:28 AM
