Freeze Plug Advice
Old Jan 5, 2005 | 01:03 PM
cditrani's Avatar
Freeze Plug Advice
I have a leaking freeze plug that I need to change. It's the small one on the passenger side of the back of the head. I'm soliciting any general advice anyone who's changed a freeze plug might have, and I'd love to hear from anyone who's changed this particular one (it looks like it will be tough but not impossible to get to). One specific question: Should the new plug go in with RTV or some other sealant?
Advice appreciated.
Old Jan 5, 2005 | 10:00 PM
Supermod56's Avatar
Most guys use the red Permatex on freeze plugs, some put them in dry. If you know the size and it's small enough, you can pipe thread the hole and put a allen head or square drive plug in it, then you never have to worry about it again! that paticular plug you are talking about on my 01 already has a pipe plug in it, although I don't know what size, but it's big.
Tom
Old Jan 5, 2005 | 10:33 PM
Stamey's Avatar
I've always used that Copper Coat, or whatever it's called, with the copper flecks in it, on freeze plug installs. I don't know why, it's just the way I was shown to do it.
Chris
Old Jan 6, 2005 | 12:01 AM
Hemi Cat's Avatar
I always use the liquid permatex in the bottle on freeze plugs. Never put them in dry. Some people use the rtv but I've seen a few seep after some time.
Old Jan 6, 2005 | 07:51 AM
cditrani's Avatar
Thanks guys. My major worry now is how the heck to get the old one out.
Old Jan 7, 2005 | 12:22 AM
Hemi Cat's Avatar
My first choice is to drill or punch a small hole in the plug towards one side and run a large screw into it, then use a slide hammer puller to remove it. I don't know if you have enough room to do that, Maybe grab the screw with a set of dykes prying against a block, sometimes punching it in and turning it sideways and grabbing it with a pliers to pull it. Maybe a slide hammer on visegrips grabbing the screw, that would give you an angle to pull from. When they are in a tight spot like that , you sometimes have to be creative using the tools available to get the job done. Good luck.
Old Jan 7, 2005 | 08:36 AM
cditrani's Avatar
I bought a right-angle adapter head for my Dremel tool last night, and I can just get it in there to drill a hole in the plug (no way a full-size right-angle drill will fit back there). To bad my grandfather (oral surgeon) isn't still alive - between the high-speed drill and working with a mirror, this is going to be a lot like dental surgery.
royta
Nov 25, 2016 11:48 AM
bigragu
Jul 29, 2014 11:36 PM
Lyall
Sep 7, 2006 06:38 AM
screaminbanana
Jun 2, 2005 07:51 PM
dsljunkie
Apr 29, 2004 11:42 PM
