Engine stumble
Old Dec 4, 2004 | 09:48 PM
fschiola's Avatar
Engine stumble
When I run about 2300 RPM in my 2000, the engine feels like it's starting to stumble. It only does this in 4th gear. I think that may be due to the engine loading in that gear. I can run WOT in 5th and there is no stumble, but I haven't tried to run it at 2300 RPM in that gear (way too fast). Could this be a sign of the lift pump going out?
Old Dec 5, 2004 | 12:59 AM
Kyle Graham's Avatar
It is a possibility do you have guages in truck if not you may have schrader valve on the vp44 there will be a cap on the driverside you can remove get yourself a guage something that reads 0-20psi some diesel fuel hose about 7 feet and a shraeder valve you can pick these up at refrigeration repair house's.
Old Dec 5, 2004 | 09:35 AM
fschiola's Avatar
No gauges, I'll try to locate a pressure guage and check it.
Old Dec 11, 2004 | 04:10 PM
fschiola's Avatar
Checked the pressure, it was 0 PSI. It hasen't done it since that first time. BTW I changed out the lift pump.
rustram96
Jan 24, 2008 08:14 PM
ramman21921
May 16, 2006 06:07 PM
03CumminZ4X4
Jan 23, 2006 01:49 PM
spudman
0
Mar 9, 2004 08:12 PM
G_T
Oct 19, 2003 05:07 PM
