engine mounts
Old Jul 24, 2007 | 08:18 AM
Fishbait's Avatar
engine mounts
Repost from other forum--(no response) -Ok other than the obvious how do you tell if one of the motor mounts is bad on the 24V truck? How do you check this? I have 217K on it now and wonder if some of the low frequency vibes I feel when I ride over semi bumpy areas of the road may be attributed to the mounts?
Any ideas other than the vague manual on changing out also...?
Thanks!
Old Jul 24, 2007 | 04:27 PM
BC847's Avatar
1st Generation Admin
Fish,
When my mount(s) bought the farm, I was able to put the truck in gear (auto), stand on the brake, and build about ten pounds boost. While doing so, I could see the engine lift and lean to the passengers side by a good inch or two.
I have no clue as to how similar a 1st Gen and later trucks are but for what it's worth, here's how I replaced them in my heap ~ https://www.dieseltruckresource.com/...d.php?t=158316
If anything, it'll give you an idea as to what you're in for.
Hope this helps.
BC847
Mar 16, 2015 05:20 PM
stillsmokin
Aug 14, 2008 05:10 PM
tinkertoys
May 9, 2008 06:16 PM
tinkertoys
May 9, 2008 02:31 PM
Junk Yard Dog
Jun 19, 2005 08:18 PM
