Engine Clicking sometimes before starting
Old Dec 1, 2012 | 05:58 PM
yukon mike's Avatar
So... when i go to start my truck it just clicks like the battery is dead, i turn the key off and try again and it turns over and starts no problem. Any ideas? i was thinking maybe the starter is going, i just installed 2 new batteries about 1 month ago, could it be a loose connection? Thanks for any advice.
Old Dec 1, 2012 | 07:44 PM
DusterHauler's Avatar
Yes it sounds like your starter solenoid is going to give out I had it with a 96 1/2 ton 5.2 two winters ago same problem.
Old Dec 1, 2012 | 07:52 PM
SIXSLUG's Avatar
Starter contacts, easy fix.
I got heavy duty ones from the local battery place, $6.75 for both.
Look just like Larry B's 30 dollar ones!
Old Dec 2, 2012 | 08:49 AM
dg164's Avatar
Yup these guys are right, same thing happened with mine two months ago, i had to use the ol hammer against the starter trick a couple times
Old Dec 2, 2012 | 11:20 AM
yukon mike's Avatar
Thanks everyone for confirming what i thought. looks like I'll be getting my hands dirty.
Old Dec 2, 2012 | 11:34 AM
SIXSLUG's Avatar
You may find you need a new plunger, but most times the original is ok. There are three or four different ones so you can't plan ahead and have one handy til you know which one you have, measure it and get a back up for next time if you are really out in the stix.
stanbnv
Jul 5, 2011 11:10 AM
The_Head
May 10, 2011 06:20 PM
Beast2B
Dec 8, 2009 01:44 PM
mr300x11
Oct 11, 2007 08:46 PM
Dave88LX
Mar 2, 2007 04:23 PM
