Do codes reset them selves?
Old May 24, 2004 | 04:56 AM
2500CTD's Avatar
Unhappy Do codes reset them selves?
I was meesing with the fuse box and pulled out #9. Now the truck has a p1693. Since i am convinced this was owner induced, if nothing really is wrong, will the code reset it self after so many key starts? Thx
-Bob
Old May 24, 2004 | 09:28 AM
dodgediesel4x4's Avatar
Some codes do reset themselves. Is this the only code that the truck is throwing? P1693 is a companion code set between the PCM and ECM. If the code doesn't go away after a few starts, which I think it should, then you can try unhooking the battery cables for 30 mins or so. If you do decide to do that, then you mind as well reset the apps, it wouldn't do anything but help.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Good luck,
Hunter
Old May 24, 2004 | 10:06 AM
2500CTD's Avatar
Yes the only code it has. The wife is taking the truck today. So I will see if the code resets. If not I'll do as you said. Thanks again
Bob
Old May 24, 2004 | 11:01 AM
HOHN's Avatar
IIRC, it takes 40 off-on cycles for the code to reset itself. It will only do this if the fault that caused the code is not present for those 40 off-on cycles.
Justin
Old May 24, 2004 | 10:31 PM
Stamey's Avatar
I don't think the code ever goes away unless it's specifically cleared by a diagnostic computer. If the code condition doesn't occur for 3 cycles of the key, and run time of some amount of time I do not know, it will stop lighting the Check Engine light. I went through this when I had a VP44 code because my PM3 wire was loose.
When I was at Cummins, I found that they could see my overheat codes, and how many there were in my ECM, from when I was driving around with a cracked block, having to refill the radiator every 15 miles or so.
I don't know about the Dodge PCM though. Cummins said they could not talk to that one.
Chris
flynhigh205
Mar 8, 2006 05:21 PM
snookinaround
Apr 7, 2005 04:24 PM
zulusafari
Aug 22, 2004 05:55 PM
rmb93243
Jul 9, 2004 12:51 AM
jt
Nov 17, 2003 05:26 PM
