diferential cover
Old Dec 25, 2002 | 12:15 AM
cummins1's Avatar
diferential cover
I am planning on changing differential gear oil to synthetic, I am also contemplating installing mag-hytek cover,does anyone have any experience with this product.My truck is a 01,3500 CTD Thanks in advance .....Mike
Old Dec 25, 2002 | 01:24 AM
Fishin2Deep4U's Avatar
Re:diferential cover
I personally do not have one, but I have helped put one on. It's slick! I want them for mine too. Absolutely a great investment.<br><br>Dave
Old Dec 25, 2002 | 02:26 AM
Dieseldude4x4's Avatar
It will be one of the best investments you can make for the rear axle anyway. I put one on mine before the truck was a year old. If I remember right, the rear end holds near eight quarts now. Plus it looks really cool and several people see the two speed rear end switch I use for the Jacobs cut out and the cover and ask me if I have installed a two speed rear end.<br>Just make sure the sealing surface on the axle is clean and dry and don't over tighten the new bolts. The new cover uses an o-ring for a seal. Mine has not leaked a drop in over three years. I used the big A with no friction modifier.<br>Good luck.
Old Dec 26, 2002 | 08:08 AM
BarryG's Avatar
Ditto what DD4x4 said. I used a wire brush on the end of drill to clean off all the gasket sealer. Just place a towel over the innards and go to town. Only took a couple minutes and it does a great job and you don't have to worry about marring the sealing surface. Not sure on the 80's but my 70 had a number stamped in the seal area and just a dab of silicone wiped into the stamp (per the maghytec instrtuction sheet) has worked great for 40k now on the rear. Also used the big A with no modifier.
Old Dec 26, 2002 | 08:54 AM
TPilaske's Avatar
Mag-Hytec cover is well worth it! I have the front &amp; rear diff covers and the double deep tranny pan.... ;D<br><br>Tony
J-man
May 15, 2010 06:07 PM
displacedtexan
17
Dec 7, 2006 09:13 PM
Badd Dogg Guy19
17
May 27, 2005 12:43 PM
suzukiZrider
Jan 13, 2005 08:20 PM
Commatoze
0
Oct 15, 2003 12:33 PM
