dial-up/ Help with codes
Old Apr 15, 2006 | 08:36 AM
Copenhagenjunkie's Avatar
Unhappy dial-up/ Help with codes
Crusing down 1-80 engine cut out several times in 2 miles on a 900 mile trip. Pulled codes 1689 and 1693. I am using dial up and can't search fast enough.
Help.
Old Apr 15, 2006 | 08:49 AM
nitrousn's Avatar
1689 no communication between ecm and injection pump module. the 1693 is just the companion code.
Old Apr 15, 2006 | 09:37 PM
Thanks..............
Does that mean the ip is on it's way out?
Old Apr 16, 2006 | 08:00 AM
nitrousn's Avatar
I am not sure but it sounds more like a wiring problem.
Old Apr 18, 2006 | 04:40 PM
Question New info- help
Forgot to mention this was the first time pulling w/ the stock trailer since injector swap, new turbo and new head. I did have slight hiccups before the trip under acceleration up hills on interstate.
Got home early this morning, on the flats across nebraska it ran great. Going I-80 west across wyoming every hill I came too it would (buck, hiccup, miss) but different than what I described above. I was going about 65-70 to keep egts safe with the 50 mph headwind. So I just checked the codes again and they came out in this order.....
1689 no comm
1693 companion
1682 what is this?
1689 no comm
I wonder if I should have dodge check codes further to see what the companion code is about?
I do need to get a 4" exhaust because I was able to hit 1200 waaaay to easily and still had alot of pedal left to use if it weren't for the huge miss.
I am going to clean the connections but am wondering if the vp is dying (no white smoke though must be electrical) or if the ecm is dying, also wondering about the crankshaft position sensor.
Old Apr 18, 2006 | 06:43 PM
Paintpusher's Avatar
sounds like a fun ride home
6spd05Dually
May 8, 2011 01:19 PM
big jimmy
Jun 29, 2010 08:13 PM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
