Cummins Part Numbers Needed!
Old Jan 27, 2006 | 08:11 PM
Mopar1973man's Avatar
Ok you guru's out there!
I'm needing the Cummins part numbers for a 2002 Dodge Cummins...
  • MAP Sensor
  • IAT Sensor
I know this is a old question but the last time I starting digging for it I got a part number for a 1997 which I not sure is going to be the same. So I will ask you guys (and gals) here for the information I need...
Please Help...
Old Jan 27, 2006 | 08:16 PM
jrs_dodge_diesel's Avatar
Try this from the Tech Facts section.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Jan 27, 2006 | 08:18 PM
Sorry Jr Those are mopar numbers and the 2002 IAT sensor isn't list anyways... I'm needing the cummins numbers...
Old Jan 28, 2006 | 12:35 AM
Smkndzl's Avatar
give me your engine ser. # and I can get the Cummins part numbers
Old Jan 28, 2006 | 06:25 AM
I believe he has the same engine that I have albeit a different tranny.
If this helps :
Engine serial # 56745776
CPL # 2902
Old Jan 28, 2006 | 08:08 AM
I chase it down this morning once the sun rises so I can see the numbers...
Old Jan 28, 2006 | 08:51 AM
Rammin On's Avatar
MAP Sensor 4077278
IAT Sensor 3408345
Old Jan 28, 2006 | 10:06 AM
CPL - 8032
Serial - 56923371
If this helps :
CPL # 2902
Huge difference in numbers here... Thanks for trying though...
Old Jan 28, 2006 | 11:36 AM
Haulin_in_Dixie's Avatar
I see this all the time and wonder why. Just give the serial number to the Cummins parts counter and they will give you the right part. Never had a wrong part with that method. My numbers are in their computer system.
Old Jan 28, 2006 | 12:59 PM
Smkndzl's Avatar
here is the info on your engine
Original
Engine Serial Number 56923371
Shop Order # SO98053
Plant BEX - B-SERIES EXPANSION SITE
Build Date 14 May 2002
Customer Number 1358
Customer Name NO WARRANTY COV
Fuel Pump Part # 3937671
Fuel Pump Calibr. GK93
Film Card T
Engine Config # D403072BB44
CPL # CPL8032
Model Name ISB-235 DODGE PICK
Boost sensor 4088226
IAT 3408345
MAP Sensor 4077278 has been superseded to 4088226
Old Jan 28, 2006 | 03:26 PM
Originally Posted by Mopar1973man
CPL - 8032
Serial - 56923371
Hmmm. I wonder why they are different? Mines a 01.5 and yours is an 02. Only apparent difference I can see is yours has a different tranny. Is yours also a High Output (245 HP) ?
Old Jan 28, 2006 | 06:47 PM
2002 Dodge Cummins
5 Speed Trans
235 HP - SO (Standard Output)
460 FT/TQ
Lil' ol' 6 Banger...
Old Jan 28, 2006 | 07:03 PM
2002 Dodge Cummins
5 Speed Trans
460 FT/TQ
Same as what I have, except for the auto tranny.
Mine is also the 235 HP 460 TQ Standard output engine.
Now I am really intrigued because the CPL #'s are different.
Old Jan 29, 2006 | 08:04 AM
Take a look here... This is the only thing I could find conserning CPL's...
http://dodgeram.org/tech/dsl/Facts/Cpl.htm
Old Jan 7, 2007 | 09:50 PM
Original
Film Card T
CPL # CPL8032
IAT 3408345
Can anyone verify these numbers are still correct for both MAP and IAT sensres for a 2002 Dodge Cummins???
