cummins flow rate
Old Jul 2, 2008 | 06:18 PM
tmar04's Avatar
cummins flow rate
I plan to install a primary fuel water separater on my frame rail. it is Napa 3192, with flow rate of 6-8 gpm, 10 micron. I already have installed a vulcanperformance 'Big line kit' from tank to inj pump. using OEM lift pump on rail. OEM filter still in place. I just want to filter as much out before fuel gets to OEM filter, and IP. will this be enough of a flow (6-8 gpm) to not cause a restriction, or unnecessary load on the OEM lift pump. I am getting 14 PSI at idle and 10 'wOT, and about 12 at 2000 rpm. thx for all info.
Old Jul 3, 2008 | 08:54 PM
dozer12216's Avatar
Buy and use clean fuel and your filtering worries are gone. Using fuel from a farm fuel tank is bad news. Even worse if removed from equipment.
6 gpm is more than sufficent for needs of IP.
Old Jul 4, 2008 | 06:02 PM
bent valves's Avatar
Just for the info, the stock carter lift pump free flows about 100 GPH on a good day.
Old Jul 5, 2008 | 12:20 PM
tmar04's Avatar
thx to both you guys.
YounanDiesel
Oct 27, 2011 09:00 PM
skydiver41
Sep 6, 2006 04:09 PM
Lrdchaos
Sep 5, 2005 03:36 PM
jethroish
16
Jan 18, 2005 04:00 PM
tony
Jan 8, 2005 06:10 PM
