crazy diesel leak
crazy diesel leak
since i changed my injectors my truck has been leaking diesel. It leaks a little while running but it seems when i turn off the truck it leaks quite a bit more and leaves a pretty good size puddle. can anyone help me please???
Did you change them yourself ?
Check the fuel line nuts at the head to make sure the are snug and tight . Really nowhere else it could be leaking from except if you loosened the lines at the pump , or one of the fuel lines to the head has a crack in them .
buzzinhalfdoz
Jan 25, 2009 06:15 PM
Atlantic4x4
Sep 8, 2006 09:20 AM
