Crankshaft Front Seal
Old Aug 24, 2014 | 08:25 PM
george7941's Avatar
The factory oil seal leaked at 155k km/6200 engine hours, the replacement went at 254k km/10200 hours. I expect I will be replacing the seal again in the near future.
Has anyone replaced the seal without taking off the gear cover? Cummins wants the gear cover removed and the seal driven in from the inside of the cover. The Haynes manual for the Ram trucks shows the seal being replaced without taking the cover off. I tried once without taking the cover off and I just could not drive the seal in. I ended up damaging the seal and had to go buy a new one.
Last time I used The Right Stuff gasket maker on the cover. It is really sticky stuff, so I expect some difficulty taking the cover off next time and cleaning the gasket residue off. Cummins does not have a gasket for the front cover, are there any aftermarket vendors with a gasket?
Old Aug 24, 2014 | 10:35 PM
mini14's Avatar
https://www.dieseltruckresource.com/...t-t126282.html
Old Aug 27, 2014 | 05:11 PM
george7941's Avatar
Strange, in the post linked to, the author mentions Cummins FSM showing the seal installed with the cover in place. I have the Cummins FSM, Troubleshooting and Repair Manual for ISB and QSB5.9 Engines, Cummins publication number 3666193-01 and it asks you to remove the cover to install the crank seal. I took a photo of a relevant page
http://i299.photobucket.com/albums/m...1/100_0521.jpg
Next time I change the seal, I will try pressing it in with a 2x4, without removing the cover, as shown in that post.
Old Aug 27, 2014 | 11:10 PM
roughstock's Avatar
ive only done them by taking the cover off and resealing the cover with RTV silicone, I don't believe a gasket is available any more and cummins recommends grey RTV
Old Sep 4, 2014 | 06:49 PM
mini14's Avatar
If I recall correctly the gasket for the 12v fits but mine was done without removing the cover and once with the cover off using grey rtv
BC847
Dec 28, 2021 02:34 PM
oilbob
Jun 2, 2010 01:40 PM
richard
Jan 1, 2007 07:22 PM
Trebor
Nov 25, 2006 12:43 PM
bobw
Nov 16, 2003 09:40 PM
