Coolant level
Old Apr 4, 2003 | 08:35 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Coolant level
Probably an air pocket in the block or heater core.
Turn the heat all the way to hot, and get the engine warm enough to open the thermostat. Recheck the level.
Carry the bottle with you and recheck after a day or so.
Old Apr 4, 2003 | 10:42 PM
Stamey's Avatar
Re:Coolant level
I agree with Shovelhead. You have to get it hot enough to get the thermostat to open before you can fill it completely.<br><br>Chris
Old Apr 5, 2003 | 06:00 AM
Dieseldude4x4's Avatar
Re:Coolant level
I assume you put the t-stat in with the jiggle pin or orifice in the right position. I think they still have them anyway. Be careful running that thing till you make sure the coolant system is completely full.
Old Apr 5, 2003 | 12:21 PM
AKDSLDOG's Avatar
Re:Coolant level
Let her run at operating temp for at least 10-15 mins, then bring water with you and leave your cap &quot;loose&quot; and go for a drive on a bumpy road. You deffinatly have a air lock in there.
Old Apr 6, 2003 | 08:20 AM
AlpineRAM's Avatar
Re:Coolant level
Just fill up the reservoir when the engine is at operating temps. If your radiator cap is ok it will suck the water in when cooling down. <br><br>Just 2c<br><br>AlpineRAM
jmccart
Jun 14, 2008 10:29 AM
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
