Convert 2001 4X4 Drums to Rotors
Old Jan 28, 2011 | 11:57 AM
cyawallac's Avatar
Short an sweet, Anyone know how much trouble it would be to convert from rear brake drums to rotors. Any thoughts would be appreciated
Old Apr 4, 2011 | 08:28 AM
linginfelter70's Avatar
eh
they arent too bad i did em on my girfreinds pontiac a while back ( i know diff setup) but you can get kits through some specialty shops brembo makes some and raebesto i think too..but the price isnt light either..
Old Apr 4, 2011 | 02:18 PM
SIXSLUG's Avatar
You will also need the proportioning valve assembly and I believe ABS stuff.
You may be further ahead finding a donor disc brake axle with the hardware already welded in place. You can swap gears if the ratios aren't the same and the axles are both D70's or D80's.
Old Apr 5, 2011 | 12:41 AM
slowflyer2112's Avatar
I would do the front upgrade long before I did the rears.........70% of your braking comes from the front so lets say that the disc brakes in the rear are a 20% improvement over the drums then your only talking about a six percent improvement overall. If you did the fronts you'll get a 33% improvement over the stocks and your total improvement will be 23% over all.
The cost of doing this will be about $130 more then the putting new stock brakes on. Pretty cheap if you already have seventeen inch or larger wheels.
good luck
Oh and I forgot to mention that the parking brake on the rear disc brakes suck.......compared to the drums
Old Apr 5, 2011 | 07:33 AM
nickg's Avatar
agreed, I too have the larger fronts, and prior to doing them I thought the rears would be the way to go...but the improvement gained from doing the fronts has far out weighed anything I can get from my rears, also drum rears do have a working/holding park brake set up vs rear disc P-brake
if you have not seen this link, it will show whats involved with pictures and part numbers
http://www.cumminsforum.com/forum/98...6k-beware.html
Old Apr 5, 2011 | 08:27 AM
torquefan's Avatar
good luck
Good post. I agree completely. After working on these trucks for years, I am very happy to have rear drums and think discs would be a step backwards. The rear discs really don't handle the crap that gets kicked up by the front tires, so the slides will constantly be seizing up. Also, as mentioned, the emergency brakes will be almost useless.
Old Apr 5, 2011 | 11:39 PM
totalloser's Avatar
17" wheels clear the third gen fronts on your truck! Find yourself some 17"+ wheels, and pick up the following for the STOOPID EASY conversion.
04 caliper brackets
04 pads and rotors
04 dust shields if you want to add a pita to it. (not needed)
You won't BELIEVE the difference!
LockedandLoaded
13
Mar 24, 2008 12:16 AM
Firstgenfanatic
Dec 23, 2007 01:14 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
slim51015
Oct 4, 2005 07:36 PM
Amish hauler
Jun 16, 2004 10:05 PM
