Cold running??
Cold running??
I am kinda new to the whole diesel thing so this may be a dumb question... Why exactly does it hurt an engine to run it hard when cold, and so important to warm up properly??? and what does it do to it?? because i just saw a thread on here saying its more detrimental to leave the truck idling for ten minutes than to cut it off and start up again... Thanks -A.Wall
If the combustion temps drop enough, all the Diesel isn't burnt and it starts sticking to the valves leading to broken parts.
If you have a device to keep the idle up over 1k, this keeps the temps up enough to prevent this.
phox
phox
Happy medium.
You don't want to idle too much, but you don't want to drive a cold engine.
I have the cold weather idle in my ECM, after startup on really cold mornings, it gradually brings the idle up to 1200ish which gets the heat going quicker.
You can have it programmed in by any Dodge Dealer who knows how, they'll most likely charge 1/2 hour shop time to do this.
Here's the TSB outlining the procedure:
http://dodgeram.info/tsb/2001/18-019-01.htm
Most people just start up, let idle a couple minutes, then take it easy for the first couple of miles, then drive normal.
phox
phox
Well the SMarty has a cold weather high-idle feature. Alright because what i've been doing is lettin her idle about 4-5 minutes and then just driving easy till get up to temp. Thanks - I've just heard so many different opinions on this
After it gets warmed up, could running your egt's on up burn out that fuel tahts stuck to the valves?
The real key, IMO, is to get the OIL up to operating temp... which, on a Cummins, takes a bit longer. When I had an oil temp gauge, it would take 10 miles at 60 mph on a 30* morning to get oil up to 190* (avg cruising temp). Took about half that long in the summer.
On your original question... the biggest danger to running a cold engine hard (with extra HP) is blowing the head gasket. Have seen it happen at just 40 psi boost on a cool engine!
RJ
akhunter68
Oct 31, 2006 05:07 PM
joel
Jan 22, 2005 08:59 PM
BEHRMAN
Dec 24, 2004 11:05 PM
