Codes?
put the key in the ignition and turn it on and off three times (never starting the truck or turning it over) look where the odometer is that is where your codes will come up have pen and paper ready they go pretty fast. I believe they will start with the letter P and when it's done it reads done. Take care!
Not all codes will be cleared by disconnecting the battery. Some will require a scanner to clear. All ODB 2 connectors are within the passenger compartment within 2 feet of the steering column.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
StormTrooper
Mar 28, 2005 09:17 AM
How do you get the codes? Do you sequence the key a certain way? And when you do it.. what should it say if everything is normal? Thanks in advance.
