circulating tank heater install
Old Dec 23, 2008 | 06:07 PM
Big Boat Puller's Avatar
well the stock block heater finaly gave out, (200K) bought a 1500 watt circulating heater, took the stock block heater out ( located in front of turbo on block) used a pipe bushing to reduce down to 3/8 pipe, hooked hose from there to heater intake, heater out went to heater hose that goes to radiator ( T into this hose ) works a lot better than stock, as soon as i start it the temp starts to move off 140 and there is allready heat at the heater vent. it was -25 F the other day and no worries.
Old Dec 23, 2008 | 08:59 PM
biododge1's Avatar
just in case, does yours have a little check ball that rattles in the heater when running? if so from time to time listen for it, mine jammed and the heater overheated and ruptured
Sevir
21
Jan 21, 2013 07:27 PM
tool
Jan 8, 2010 07:38 PM
Igor
14
Nov 8, 2005 10:40 AM
Toby
Apr 6, 2005 12:31 PM
2500CTD
Feb 27, 2005 01:29 AM
