bouncing tachometer
Old Dec 9, 2003 | 12:11 PM
Palmetto_kid's Avatar
bouncing tachometer
while sitting at an idle, my tach will slightly bounce. myabe 1/4". THe engine rpm does not change. is this a sign of my ckp sensor going out?
Old Dec 9, 2003 | 12:14 PM
BigBlue's Avatar
Re:bouncing tachometer
They all do it. Mine's done it since day one. Been fine for 50K miles and 2 years. Don't worry about it.
Old Dec 9, 2003 | 07:22 PM
phox_mulder's Avatar
The tachometer, like everything else is controlled by the computer.
It's not an "actual" measure of really anything.
Same with the speedometer, oil pressure, engine temp, etc.
Perfectly within normal parameters.
phox
Old Dec 10, 2003 | 07:44 AM
jrs_dodge_diesel's Avatar
I thought I had a bad sensor. After reading this I am sure its normal.
Old Dec 10, 2003 | 10:54 AM
Diesel Dave's Avatar
Mine does the same thing. Like Big Blue and Phox said, it is normal with these trucks.
Old Dec 11, 2003 | 04:47 PM
dieselgeek's Avatar
Mine did that since day one. However, at about 100,000 miles the CKP sensor went bad. After it was replaced, the tach does not bounce anymore. Unless you're throwing CKP codes, I wuoldn't worry about it.
bulabula
Jul 30, 2003 08:25 AM
chrismez
Jul 17, 2003 08:55 PM
DODGEBRIAN
May 30, 2003 10:28 PM
dsljunkie
Mar 28, 2003 12:05 PM
Evildiesel
Mar 26, 2003 08:55 PM
