Black smoke?
Old Sep 24, 2009 | 08:33 PM
RAMMINVA's Avatar
Black smoke?
What can I or to My new 24 valve to blow some black smoke? Don't want to chip it. Thanks
Old Sep 24, 2009 | 08:55 PM
Davycrockett's Avatar
you could make a smoke switch but you might need a chip for the smoke switch
Old Sep 24, 2009 | 10:12 PM
mopar-or-no-car's Avatar
chip or injectors
Old Sep 24, 2009 | 10:14 PM
77machomopar's Avatar
put a clogged air filter. hard to make a 24v smoke without a chip
Old Sep 24, 2009 | 10:46 PM
RAMMINVA's Avatar
haha sounds like the only way is a chip, i guess a chip would be ok, as long as it's a good one and as long as it doesn't effect my 53 block..
Old Sep 24, 2009 | 10:55 PM
Grider Pirate's Avatar
It'll smoke like hell if you blow an intercooler boot off! Of course, you'll also get NO power, and out the roof EGTs! Not really recommended. Personally, I'd much rather have more power, not more smoke.
Old Sep 24, 2009 | 11:14 PM
RAMMINVA's Avatar
I'm just use to my 1990 blowing smoke all over the place haha i'd like to have it like that
Old Sep 25, 2009 | 09:06 AM
my truck wasnt chipped at all and never was. the 53 blokc cracked in that. good friend of mine has a 53 block and he been running 50 psi with fire rings injectors turbo. his block is still good. i dont think a chip will make any difference in the likelihood of the block cracking
Old Sep 25, 2009 | 10:11 AM
cmac's Avatar
just be courteous when driving on public roads. blowing smoke all over gives everyone a bad rep. sure sometimes someone deserves it just dont over do it.
Old Sep 25, 2009 | 10:51 AM
RAMMINVA's Avatar
What do you guys think about the smarty programmer? I am looking it. It's cheaper than the edge juice with attitude. You just plug and play with the smarty it seems.
Old Sep 25, 2009 | 10:19 PM
mechrisme's Avatar
I newbie to these forums here but before any performance mods, a fuel pressure gauge is always good
Old Sep 25, 2009 | 10:26 PM
johnh's Avatar
WHY do you want smoke??...... install stage 3 injectors , you'll get all the smoke you want (more power too)
Old Sep 26, 2009 | 03:05 PM
dodgeguy71's Avatar
check youtube for a smoke switch, there's a guy on there that shows how to wire one up. I think you'll need the chip in order to keep from throwing codes every time you flip the switch cause it's wired into your map sensor I believe.
I thought about it once then thought about washing down the cylinders with diesel fuel and how I did'nt have spare 5.9's or trees with US dollars for leaves.
Old Sep 30, 2009 | 11:47 AM
PaulDaisy's Avatar
And why in the world would one want more smoke? I'd much prefer no smoke at all and more power.
Old Sep 30, 2009 | 12:34 PM
RAMMINVA's Avatar
i guess being younger i like the black smoke. But thats just me. Power would be good to, but i am new to the 24v world and don't anything about the pumps and such on these trucks and i wasn't sure if it was anything like the older ones. Just don't see many of these trucks smoke unless they are chipped or injedctors or something. My main intent was to see if there was anything simple do just to get a little smoke like my old truck would put out. But now i'm looking at a smarty or edge juice with aditude.
