BIG problem with DTC's.. need hellp
Old Mar 7, 2009 | 05:58 PM
dalec's Avatar
'01 2500, Edge juice with attitude, ATS co-pilot TC locker, ATS VB and 3 start TC, 4 1/2" jansen exhaust.
This is grandpa's truck. used to pull RV
Just recently, started getting P0341 error codes but truck ran fine, so cleared and waited to see what happens.. same code kept coming back (indicating the camshaft position sensor problem).. ok, so I ordered one. will be here next week.. BUT.. now I've started getting P1689 codes (no communication between ECM and injector pump), AND the danged tach just quits working after the truck runs for a while.
Can all of this be related to the Camshaft position sensor? It would seem to me that the crankshaft position sensor would be the one that controls the tach.
anyone had similar problems?
Old Mar 7, 2009 | 07:45 PM
BigIron70's Avatar
Cummins Guru
Read this thread maybe related https://www.dieseltruckresource.com/...ght=cam+sensor
Old Mar 7, 2009 | 08:07 PM
mishkaya's Avatar
I don't think the '01's have a crank position sensor (although I could be wrong on that one), so I would think the cam position sensor would be your culprit. It's a PITA to replace though. And do check your wiring to make sure that it is not damaged, as has happened before. Good luck.
mishkaya
Old Mar 7, 2009 | 11:47 PM
mini14's Avatar
2000 was the last yr for ckp, your new cam sensor should clear things up.
Old Mar 8, 2009 | 03:05 AM
JMJ's Avatar
JMJ
If the camshaft speed sensor shows a different engine speed than the speed sensor inside the vp44 you will get that 1689 code. i was having trouble with the same code showing up all the time ended up to be a cam sensor. As for 2000 being the last year of the crank sensor. When i had mine hooked up to the diagnostic tool at the local diesel shop the last time for some other codes the display showed readings from the cam, ip, and crank sensors that would lead me to belive that my 01 does have a crank sensor unless its just a calculated speed on the read out.
Old Mar 8, 2009 | 07:40 AM
dozer12216's Avatar
Your chips and their programming may be interfering. Remove and try. Communication error is generally indicator IP is going down.
The sensor can be accesed with 10 mm 1/4 drive socket and long extension if I recall. Not easy.
Old Mar 8, 2009 | 10:23 AM
Mattg4x4's Avatar
Yea real pain to change but should take care of the isuses mine was doing the same thing all set now.
Old Mar 8, 2009 | 11:14 AM
Number47's Avatar
not to be a dick but is the exhaust really 4 1/2?? because i've never heard of half size exhaust past 3 inch
Old Mar 9, 2009 | 10:38 PM
mini14's Avatar
no its all over the place starting at a 3.5" downpipe. the only 4" is after the muffler.
Old Mar 9, 2009 | 10:56 PM
huntman509's Avatar
your tach and the 1689 dtc are directly related to that cam sensor, just hope that the tone wheel on the back of the cam is not coming loose, i have only seen this once but it is possible for the screws to back out, also the 2001 cummins engine doesnt use a crank sensor(they stopped crank sensors in 99 or 2000)
Old Mar 10, 2009 | 04:18 PM
dalec's Avatar
Thanks so much to everyone for their input. I can rest a bit easier now. However, in looking at the sensor's mounting screw, it looks like an allen wrench type of screw. very hard to tell. If someone has changed theirs, what about removing that hose that's attached to the bottom of the power steering unit, that goes up to the block? That would give me a lot better access to the unit.
WhoCares79
May 24, 2009 06:58 PM
ptgarcia
14
Feb 6, 2008 02:24 PM
CTD NUT
Dec 10, 2007 01:48 PM
downlow
Mar 1, 2006 04:22 PM
