Belt Squeak On Shutdown
Old May 9, 2009 | 10:03 PM
progrower's Avatar
My truck has a belt squeak everytime I shut it off. Do I need a new belt or does it just need to be tightned. Any suggestions would be great. Thanks
Old May 9, 2009 | 10:26 PM
JohnBer's Avatar
its a cummins thing, just get used to it. dont think i have ever heard one NOT do it. the motor shuts down so quick because of compression the pulleys cant stop as fast so it squeaks.
Old May 9, 2009 | 10:30 PM
MARKY MARK's Avatar
A Goodyear Gatorback belt will make the skreetch go away. I've had mine on for a couple years and not one squeek since.
Mark
Old May 9, 2009 | 11:39 PM
WestTN's Avatar
The description of the cause of the chirp was close. What happens is caused by the high compression of these engines. As the engine is slowing to a stop it is still compressing the air in the cylinders. At some point the engine is no longer turning fast enough to push a piston all the way to the top. Rotation stops and the residual pressure in the last cylinder turns the engine backward. This unloads the tensioner and allows the belt to spin backwards on the crankshaft pulley, producing the squeak you hear. It is annoying, but harmless.
Goodyear Gatorback and a few others do not squeak.
Old May 10, 2009 | 08:22 AM
Ed ke6bnl's Avatar
Mark
gatorback and no chirp ED also
Old May 10, 2009 | 02:04 PM
lovinCTD59's Avatar
I love my Gates belt... Its nice and loud!!!
However I ran a Gatorback, not knowing that it solved the problem and it did. But I change mine once a year no matter the condition its in.. Cheap insurnace IMHO
Old May 10, 2009 | 02:07 PM
SIXSLUG's Avatar
I put on a MOPAR belt last August and the skreek stopped, but its slowly coming back. Its normal and you can't really tighten it, its on a tensioner.
Kurt
Old May 10, 2009 | 03:49 PM
progrower's Avatar
I might have to try one of them goodyear gatorback belts. I don't like pulling up somewhere and shuttin it off and people wonder what the squeak is.
Old May 12, 2009 | 04:01 PM
tbrunson's Avatar
gatorback works well.
Old May 13, 2009 | 11:28 AM
Diesel Demon's Avatar
I have had a gatorback belt on my 2001.5 for over a year still no squeak at shut down.
Old May 13, 2009 | 03:49 PM
Mechanos's Avatar
If you're just worried about what other people wonder about..... I think you worry too much.
Old May 13, 2009 | 04:41 PM
HotRodTodd's Avatar
I would be worried if mine didn't do it, motor getting weak, low on compression, oh the horror!
Old May 14, 2009 | 10:39 AM
nkennedy's Avatar
I like the little squeak. Lets me know the engines still tight.
Old May 15, 2009 | 09:07 AM
91r/t's Avatar
Not to get off topic but My buddy has a set of twin turbos on his truck with the FASS pump he cals the meat grinder....the other day we were at tops and some guy said" hey man your truck is making some bad noise under your bed." He smiled and said yea its a dodge you know they always make noises they are junk and drove off laughing we both were dying.
shep1
Aug 29, 2010 10:19 PM
CTD2001
15
Nov 28, 2009 07:54 PM
ytodd
Nov 2, 2007 09:57 AM
gman07
May 9, 2007 06:03 AM
hotdram
31
Sep 17, 2005 08:00 AM
