Banjo size?
Old Jul 25, 2003 | 11:02 PM
DarrellB's Avatar
Banjo size?
What size of NPT are the banjos? Are they 1/4&quot; NPT or 3/8&quot;?<br><br>Working on a new fuel system and need to know the thread size to order fittings. 8) I could take one out but if someone knows it would save some time. <br><br>Thanks<br>DB<br><br>
Old Jul 26, 2003 | 12:26 AM
KATOOM's Avatar
Re:Banjo size?
I dont really understand what you are saying but ask ROD at WILDCAT. I'm sure he knows and sells all that stuff.
Old Jul 26, 2003 | 01:18 AM
DarrellB's Avatar
Re:Banjo size?
NPT=National Pipe Thread. 8)<br><br>DB
Old Jul 26, 2003 | 01:29 AM
KATOOM's Avatar
Re:Banjo size?
I'm pretty sure its metric. Not positive on the size though. Maybe 12x.150.
Old Jul 26, 2003 | 06:48 AM
Dieseldude4x4's Avatar
Re:Banjo size?
They're not pipe thread if I remember when I changed mine out, they're closer to a standard bolt thread.
Old Jul 26, 2003 | 07:16 AM
Mexstan's Avatar
Re:Banjo size?
Don't know the size either, but knowing the job the banjo's do it cannot be a NPT which has a tapered thread. It has to be a straight thread. As KATOON said, probably metric.
Old Jul 26, 2003 | 10:02 AM
banshee's Avatar
Re:Banjo size?
KATOOM was almost right... they're M12 X 1.5. The holes (4) in the stock banjos are ~.125&quot;
Old Jul 27, 2003 | 09:59 PM
Stamey's Avatar
Re:Banjo size?
12mm x 1.5, not NPT thread. Been there, done that.<br>Just agreeing with everyone else. :<br><br>Chris
Old Jul 27, 2003 | 11:45 PM
thumper 549's Avatar
Re:Banjo size?
Just rember one thing your whole fuel system is only as big as the smallest hole . from a engineering point of view.<br> in other words ,is dose not help to increase the size if you leave just one item small or stock.
Old Jul 28, 2003 | 12:42 AM
Scotty's Avatar
Top's Younger Twin
Re:Banjo size?
[quote author=thumper 549 link=board=4;threadid=17537;start=0#164738 date=1059367558]<br> Just rember one thing your whole fuel system is only as big as the smallest hole . from a engineering point of view.<br> in other words ,is dose not help to increase the size if you leave just one item small or stock.<br>[/quote]<br><br>And I have seen systems that bottleneck to real tiny replacement fittings for the banjos...no benefit. As well as reduced inner Diam on the sweeps.
Tommy93w350
Nov 16, 2016 06:40 AM
mpracehemi
Sep 21, 2008 04:35 AM
ataboy9026
Jun 18, 2007 09:04 PM
8mpg
Jun 15, 2007 07:38 PM
