Band Adjustment Question
Following these instructions: http://cumminsdatabase.com/read.php?id=55
I have a few questions that maybe someone could clarify. It says torque the torx screw the 75lbs then back off 1 7/8th turns. Wouldn't this untorque what was just torqued? How much ATF will I loose by dropping the pan to get to the rear band? I have found that my local auto parts store (auto zone), only my transmission listed as a 47 rh not a 47re. Is there a difference in the two? Is there any recommendations to which brand of transmission filter to use? |
Originally Posted by 1998dsmtalon
(Post 2414879)
I have a few questions that maybe someone could clarify. It says torque the torx screw the 75lbs then back off 1 7/8th turns. Wouldn't this untorque what was just torqued? How much ATF will I loose by dropping the pan to get to the rear band? I have found that my local auto parts store (auto zone), only my transmission listed as a 47 rh not a 47re. Is there a difference in the two? Is there any recommendations to which brand of transmission filter to use? All of it except for what's in your torque converter. [laugh] Yours is an 47re, yes there is a defference. E is for electronic.... H is for hydraulic. The older, non-computer controlled trans were H. Not sure on the brand, but tell them you want a filter for a '96 2500 diesel truck. The element is a much better flowing design than the newer style crap that's probably in your '01 now. You will see the difference when you drop the pan. |
Awesome, thanks for the info.
How much ATF +4 should I be loading into my shopping cart? I was going to by the pan gasket and filter set. Is the pan gasket the same in all 2gs? |
(Post 2414994)
How much ATF +4 should I be loading into my shopping cart? I was going to by the pan gasket and filter set. Is the pan gasket the same in all 2gs? 727, 46R_, 47R_ .... no matter, they are all the same gasket. Just ask for a filter kit for a '96, it comes with the filter and a gasket. |
Thanks again!
But I am still trying to find out about how much fluid I am going to loose when dropping the pan. |
I don't know.... I have an oversized pan and I also drain the TC when I adj. bands/change fluid/change filter. So it will be different than the amount you'll lose.
1 Attachment(s)
I think it's around 5 quarts or so.... I used the shadetree mechanic band adjustment and it works fine. Check here for more info on the tranny band adjustment from ATS:
Attachment 26806 |
just remember, inch pounds...not foot pounds.
I would buy seven quarts just to be safe.
Originally Posted by annabelle
(Post 2415431)
yeah 7 quarts is the correct amount, i would use the atf+4 it is made with a slip modifier for your lock up torque converter
Originally Posted by Mechanos
(Post 2415042)
None IMO.... I wouldn't touch that +4 junk if you offered me a lifetime supply. I use Dexron with a bottle of Lube Gaurd Red.
7 quarts if dropping the pan
Originally Posted by mini14
(Post 2415419)
(Post 2415056)
Thanks again!
But I am still trying to find out about how much fluid I am going to loose when dropping the pan. -6 Qts if not changing filter; mught as well anytime you drop the pan!:) -11 Qts if filter and a Deep Dish Mag Hy-Tec Pan. (just FYI). You don't list location, but if in the south, these pans and their higher capacity, make a big difference in tranny running cooler and longer in high summer temps. I agree with 'Mechanos' ...... get earlier filter. Better filtration. Only one aftermarket, DTT trannies use. RJ |
| All times are GMT -5. The time now is 06:24 AM. |
