Ball joint removal video
Old Sep 9, 2012 | 03:30 PM
craigwill's Avatar
Found this on youtube.
part 1
http://www.youtube.com/watch?v=aVu3MnNnoBI
part2
http://www.youtube.com/watch?v=DaoUD...feature=relmfu
part3
http://www.youtube.com/watch?v=yJNmb...feature=relmfu
Craig
Old Sep 9, 2012 | 06:51 PM
BigIron70's Avatar
Cummins Guru
Good video, always looks soo easy when seen on youtube. Best to use mechanic wire to hold the caliper up. Otherwise it will always fall down on you when you lease expect it to. Ouch.
Old Sep 18, 2012 | 03:09 PM
craigwill's Avatar
ball joints
OK. So this is how the replacement went. The procedure using the steering to press out the axle bearing worked great. I spent more time finding (sae,metric) sockets, and the ball joint press adapter(harbor freight) than the job took. Top joint pressed thru the top of the joint so I had to use a socket to press the remaining part out the top. the bottom joint I put pressure on the ball joint and a wack of a hammer broke it loose. I found the 43mm/1 11/16 axle socket at Sears. Not too bad of a job. I give it a 7 out of 10. My pleasure is that the shop I got an estimate($850.00 at said I would F it up and have to be towed to them. Ha ha. total cost upper/lower joints and 2 U joints $323.00 from Rock Auto and about $30.0 for misc sockets. 18 pack of Mic Ultra.
Craig
Old Sep 18, 2012 | 08:24 PM
Silver R/T's Avatar
Feels good to know you've saved a bunch of money, doesn't it?
Old Sep 19, 2012 | 06:26 AM
high bid's Avatar
Thanks for the info....wanna come over to help this wknd. Installing Carli suspension also. Something is loose on the frontend and BJ have never been done w/219k....so im guessing theyre going to be the issue but im also wondering if its the skyjunker control arm bushings AGAIN. Ill supply the drinks!
Old Oct 27, 2012 | 04:14 PM
high bid's Avatar
Update....bj are fine, no slack/play but now that it's all apart I'm stuck removing the top....they won't let loose?..help
72dart
Jun 19, 2012 10:42 PM
edd209
0
Sep 17, 2010 09:08 AM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
