Ball Joint Press question...
Old Jan 20, 2008 | 05:41 PM
JHew84's Avatar
Alright I've been searching for the past few days now trying to find a write-up I am quite positive I read a few weeks ago... no it's not the one hosted on pavementsucks...
basically I'm trying to figure out which combination of adapters i need to use to press out the ball joints on my '02 2500 4x4....... I just can't seem to get any kind of combination that seats correctly and the ones that kinda-sorta seat I'm worried will explode when i get it under enough pressure.
I bought the harbor freight press kit and the adapter kit to go along with it, and I am still having trouble...... am I just not getting the right combo? I know a lot of you guys are using the same kit so I'm hoping someone can tell me the exact adapters that need to be used so I can stop guessing.
Old Jan 20, 2008 | 06:46 PM
rockwithjason's Avatar
i used the harbor freight kit to press mine out. i didn't have any trouble with the adapters. if you have an autozone near you their rental unit will work as well.
Old Jan 21, 2008 | 11:11 AM
JHew84's Avatar
do you happen to remember the #'s of the adapters you used? with the extra kit the numbers start at 1 in the upper left hand corner and end at 14 in the lower right... I've tried flipping certain ones around, using ones that are too small and only fit the shaft of the balljoint, etc, I just can't seem to find a good combination. I'm starting to think I either A) got a bad kit from HF, or B) something is funky about my truck ...
Old Jan 21, 2008 | 11:51 AM
it was two years ago, sorry can't help you.
Old Jan 21, 2008 | 12:18 PM
JHew84's Avatar
, crap...
I'm just trying to be productive in the meantime while I wait until I can get my tanks filled... the only heat I have at the moment is a oxy/mapp setup and that's just not hot enough I'm afraid.
Old Jan 23, 2008 | 01:20 AM
JHew84's Avatar
bueller? bueller?
I'll probably be getting my tanks filled tomorrow so I'll at least be able to heat it up and use some combination of adapters...
rokcrawlr510
GADTR #40
Apr 7, 2010 11:59 AM
neversatisfied
Jan 11, 2010 02:36 AM
TJeeper
Apr 2, 2009 11:30 AM
lniemeyer2
Jan 13, 2009 07:38 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
